'02 4.7 Durango
When coming to a stop, idle drops way down (to about 400rpm) and almost cuts the engine off. The other day, car would not stay running at all. Took AIC off, cleaned carbon from the "ball end" and cleaned as much carbon out of the injector body as I could. Car then started up and ran, but still has the idle issue.
Only problem is that I don't know if the TPS or the AIC is causing the problem. There are no trouble codes shown via my handheld monitor.
