Replacement Upper Ball Joint Bolts Torque Specs
5.1K views 0 replies 1 participant last post by  fxallen
#1 ·
Just replaced left front CV joint on my 2001 Dakota AWD.
Needed to unbolt upper ball joint to remove/replace axles.
Noticed there is no torque spec in the Service Manual for the recall fix which removed the rivets and installed three bolts to hold the upper ball joint to the upper control arm.
Would anyone know what the torque spec is/was for the recall replacement bolts on these upper ball joints ?
TIA and best to all !
Fred
