I have the Superchips programmer and a question on the three settings? What is the difference between the towing performance and performance modes? HP, Torque etc? Can anyone answer this pleeeeeeeeease!!
Yes...............yes it is!Baby Hemi said:I never tried running the controller without 93 octane in mine. In most places Super Unleaded is what .20 more per gallon than Regular? So if you purchased 20 gallons of gas you would spend an extra 4.00 for Super. Is an extra 4.00 a tank worth the extra performance?? To me it is so I don't even worry about it![]()
detonation is from a hot spot in the combustion chamber igniting the air/ fuel mixture before it should....usually way before top dead centerAmberFireDaK said:You should be able to hear it anywhere, but sometimes it can be faint. IF you think it's pingging but your not sure, drive down a street with buildings really close to the road, the sound should bounce off the buildings and back to you.
It only pingged for me when I stomped the gas and accelreated as hard as she would go. It didn't matter if I was in the city or cruisin on the highway, pretty much whenever you put the truck under heavy load
And yes pingging is bad.....it's detonation...from what I understand it's caused by the spark plug fireing alittle to late, when the exhaust valve is opening. That's why it sounds like it's comming from the back of the engine or underneith
Hope that's right
Why would superchips cause detontnation?viperkota said:detonation is from a hot spot in the combustion chamber igniting the air/ fuel mixture before it should....usually way before top dead center
Mine asks me seperately......I can raise 1 or the other...or bothSLT kota said:I have heard that you can get faster on the towing but I also think that there is a reason that there is a difference between the two settings (I haven't tried either yet).
On a side note, is there a way to remove the speed limiter without removing the rev limiter, whenever I try to remove the speed limiter it says that the rev limiter is also removed and it won't let me change it.
Thanks and sorry for the hijack,
Stuart
stuart, u have the 4.7, right? it shouldnt even alow u to move the rev limiter. my tuner flashes "change rev limit not available". do custom settings i beleive and it should ask u what you wanna change :biggthumpSLT kota said:I have heard that you can get faster on the towing but I also think that there is a reason that there is a difference between the two settings (I haven't tried either yet).
Stuart
AmberFireDaK said:Why would superchips cause detontnation?
