21 - 24 of 24 Posts
So Bogieboy what is the maximum lbs of boost you can get from pulley drops on a powerdyne (before impeller upgrade and not overspinning the stock bearings) ? just curious figuring you might know
On a box stock PD, right around 9psi is the volumetric limit of the impeller for our engines, and from what i have seen, you can pull about 12psi out of the upgraded impeller and bearings....
Discussion starter · #24 ·
Wow, some of yall are running a blower on a motor that has no idea to increase fuel when in boost?
IRRC, I have an FMU set up if I can find it!
Let me know if you find it please.
21 - 24 of 24 Posts
