2007 Dodge Dakota SLT. Oil pressure light comes on after about 30 minutes of driving and with the engine at idle. Oil level is good, eng. temperature good/normal. Should I look at replacing Oil pump (extreme) or pressure switch?
3.7. Sender behind oil filter. 266k miles, oil change coming up. Will check/change then. May use higher viscosity oil due to age and mileage. Any recommendations?It seems like a no-brainer to change the oil pressure sender before changing the pump. Is that a 4.7? I think that the sender may be down in the vicinity of the oil filter. At least it was on the earlier 4.7s.
