I have been thinking about buying KRC's lighting killer package but is it really that good of a deal? i was just wondering if anyone out there is runing it and how they liked it?
Good for you. The people I've spoken with so far haven't been so lucky.N56629 said:So far I have over 10,000 miles on mine.
Why would you buy anything from KRC if they are making such a huge mistake?Chuck said:Good for you. The people I've spoken with so far haven't been so lucky.
The answer to that is obvious. You can't even interchange all mopar rockers. I can get some very accurate measurements of the distance between the roller and push rod end of the rocker. If they are identical then I stand by my statement about the 1.6 ratio. The only other variable is the distance from a line between those two and the pivot point.If the 3.2 motor in a BMW had 1.6 rockers in it, do you think that they would work in the Magnum?
I'm not.N56629 said:Why would you buy anything from KRC if they are making such a huge mistake?
You're fixated on that single measurement, from the fulcrum to the edges. There are characteristics to heads that require different development in the rocker design - if these characteristics are not observed you may still have the proper end to fulcrum to end design, but you'll have errors in side to side rocker offset. I'm not making hyperbole here, there's an example provided below.N56629 said:The answer to that is obvious. You can't even interchange all mopar rockers. I can get some very accurate measurements of the distance between the roller and push rod end of the rocker. If they are identical then I stand by my statement about the 1.6 ratio. The only other variable is the distance from a line between those two and the pivot point.
This is very true.N56629 said:Several problems that I'm aware of are the failure to use the correct length push rods, because even adjustable rockers have their limits. The failure to use hardened rods and to use guides. Incorrect rod length can put the roller off center and cause premature valve guide wear.
This was passed to me recently regarding the whole issue of rocker "geometry":N56629 said:If you know of something else that would change the geometery of the rocker, let me know.
N56629 said:Chuck, I'll look up the number for the rockers when I get home. Obviously they would not be for heads with canted valves otherwise the rollers would sit on the valves at an angle when place on the magnum heads.
I asked why you would buy KRC because you have a KRC 408 on your list of things to buy.
Well, I'm not a valvetrain engineer, but I play one on tv...N56629 said:Ask your friends about side loading. If I'm not mistaken there is only one point at which there is zero side load and that is the point where the axis of the valve is tangent to the arc of the rocker. Does that make sense?
Me too. It's been a long time since I've really taken a serious look. Diamler Chrysler actually has some relatively new software to analyze valvetrain geometry. Wouldn't you like to get your hands on that?Chuck said:BTW: I'm enjoying this - you're making me think. :biggthump
