can a stock 5.9 hold safely?
Bottle pressure should be at 1050psi and fuel pressure should be around 44psi. Call your kit manufacturer unless you have NX kit. If so I can give you the jet sizes.well as of right now im not "tuned right." even after i put the full exhaust back together i still get this flashing engine code when ever i rip it. i havent had time to go to the shop and check it and since i have a 99 i dont think it can do the cool little truck with the ignition to get the code.
i checked on summit and used a n02 calculator dealy thing and i got the right sizes for the hp ratings. i used 50psi fuel pessure with 500psi in the bottle, think those are reasonable? they gave me the sizes but i dont remember what they were. id install the kit but like i said i know ill get fed up and do a half ass job. but ill get it done soon enough.
I would bet the MP PCM is causing your problems. It is probably making it run too rich and throwing a code. Put the stock one back on and see if things get better. You can go to AutoZone to have them pull OBD II codes for you.ok i got the plug deal. do have a mopar PCM, what dose that change exactly? like i said i got some engine light problems right nwo that i need to take care of but once i get that taken care of im pretty much good to go right? i also have an M1 and other mods in my sig.VVV
The MP PCM just advances the timing slightly. Similar to a Superchips programmer.i wanted to do that with the stockpcm but i bought the truck with it so i dont have a stock pcm.
now i know why my truck runs rich
It also increases fuel on the WOT fuel map and changes the rev limiter and speed limiter.The MP PCM just advances the timing slightly. Similar to a Superchips programmer.
Having extra fuel while he's using nitrous isn't a bad thing as long as it's not a ridiculous amount. I highly doubt that the MP PCM is dumping so much fuel in that it's throwing codes.It also increases fuel on the WOT fuel map and changes the rev limiter and speed limiter.
Maybe not but mine did. would run so rich that I got a code. I believe it was 53 on my OBD I. He said he's getting a code when he floggs it. Just a thought from my experience.Having extra fuel while he's using nitrous isn't a bad thing as long as it's not a ridiculous amount. I highly doubt that the MP PCM is dumping so much fuel in that it's throwing codes.
