anybody know what model dakota/durango had an LSD in the back?
36K views 21 replies 15 participants last post by  9t9-5.2
#1 ·
im trying to convert my "1wd" dakota into a real 2wd lol
i heard that a can pull a rear end from a dakota or durango and slap it in my truck...if this is true can anyone tell me what models had a limited slip
my truck is a 99 dakota slt 2wd v6
#2 ·
I'm not sure if the lsd was ever "standard".....it could be that it's more like it was an "option" thing.
Someone more knowledgeable please correct me.
Mine had it from factory, but I'm pretty sure it was ordered like that. I'm the second owner and I do have the window sticker around here somewhere.
But in the yards you should be able to tell with reasonable certainty if the axle you're looking at has the lsd or not.
#6 ·
In '02, all Dakota R/T's had LSD 3.92 (9-1/4") with drum brakes as standard equipment, but LSD axles were also available as optional equipment on every other Dakota configuration you could imagine, in both 8-1/4" and 9-1/4" flavors, in all body trim packages, and in all axle ratios.
My quad cab is 4x4 and has the Trailer Tow Group option, but the LSD still had to be ordered separately because LSD was not included with any particular package outside of the R/T's. My truck also has the 9-1/4" axle, but I'm not sure why, since most of the '02 AWD trucks on this board seem to have the 8-1/4" axle.
The best bet is just to look at vehicle glove boxes and find what you are looking for (axle ratio, axle size, and LSD option are all clearly labeled on the glove box stickers). Some trucks were ordered with LSD. Most were not. All non-R/T's had drum rears up thru maybe the next generation redesign(?). R/T's switched over to disk brakes in 2003(?) or so. Outside of those parameters, any truck could have just about anything offered, and there's no way of knowing without looking.
#10 · (Edited)
Unfortunately, I think you're exactly right. The differential covers have axle ratio tags on them, but as far as I know, there is no visual indicator of any kind to tell you from the outside if an axle is LSD equipped or not.
If both rear wheels were off the ground. you could shift it into neutral and try to spin the tire on one side, and see what the tire on the other side did. Same direction equals LSD, opposite direction equals open diff. The problem is, how many times will both rear tires ever be off the ground? Outside of that method, and with no glove box sticker, then I think removing the diff cover is the only way left to know for sure.
#19 ·
I know this is old but I just ran across this thread. By problem is I have 3 durangos 98 5.2l and a 2000 5.9l and a 2001 4.7 and the dealer vind it for me and they say they all have Anti spin diffs. And all have 9.25 rear different but I opend them up and there all open diffs and 2 of them I bought from. The original owners and they said they never replaced them and the 5.9 had all invoices from 2000 till I bought it and nothing show a diff being replaced. So what gives and the dealer is clue less.
#20 ·
Just looking at it, there is nothing in the middle between the spider gears that makes it obvious it's a Trac-Lok rather than an open diff. The Trac-Lok clutches are hidden in the carrier case, behind the side gears. An open diff carrier has sloped shoulders opposite the ring gear, and a Trac-Lok carrier has a square shoulder to provide space for the clutch. See below.
Open differential:
Trac-Lok differential:
