Is it possible to unbolt the tailshaft of a 2wd and bolt a transfer case right up to it? Any info will be a big help?
hey dude just chill, these guys who acutally know stuff obviously have never done this on a dodge truck so they are tryin to help anyway they can dont get all bent out of shape if they say something that you "dont give a f about"i am doing a sas swap so i dont really give a f*@# bout the front end i just needed to know bout the transmission
ha dumba$$ tryin to get a cheap 2wd into a 4wd? dont cheap out next time ya buy a truck
I didnt see any animosity in his post, apparently baumld knows a little on what he is talking about. I think you were the one that was name calling. Another SAS? Where are the pics???:jester::mullet: Good luck finding what you need!hey dude just chill, these guys who acutally know stuff obviously have never done this on a dodge truck so they are tryin to help anyway they can dont get all bent out of shape if they say something that you "dont give a f about"
I have gotten way more familiar with this family of trans than I ever wanted to PM me if you want.it's not that easy but it can be done your best bet would be to pull the O.D. housing and have the one for the 4x4 rebuilt with new clutches at a trans shop. there is a spring that applies clutches in the OD part that is very capable of killing you so don't try to do anything with the stuff in the O.D. housing after you take it off.
Hmmm actually there is another option to this dellema. It is possible to use a twd trans and make it 4x4. I believe the old like 50 60s chev-ys had a drive shaft from the trans to the transfer case mounted in the midle of the truck to distribute weight and have the drive shafts the same lenth. Get one of those transfer cases and your all set just get drive shfts made. The only problem would be to locate them. and i beleve there heavy as hell due to the cast iron case and spure gears.ha dumba$$ tryin to get a cheap 2wd into a 4wd? dont cheap out next time ya buy a truck
Get in your Delorean time machine and go back 8 years to find somebody that cares.I was working for Chrysler when the one on the left was built. Can't stand the looks of them. The other 2 are right on. As they say, 2 out of 3 ain't bad.
