So I've been having a few issues lately with this damn trans.
It wouldn't start one morning this winter because of a connection problem (shotty terminal connectors). And bam once it started the trans was in limp mode with the p0700 code coming up. So I took it to O'Reilly's and used a real code reader to pull the actual trans codes. It read solenoid pack c and solenoid pack A failures. So I just replaced the solenoid pack as a whole last weekend, changed the filters and gasket on the trans pan, refilled the trans with the proper amount of fluid, and reset the computer ect. Still having the limp mode problem, I just want first gear back!! It's still throwing the p0700 code and I haven't had any time to run to the parts store to read the codes, I'm assuming they're the same. Any ideas what the real problem is? I'm getting tired of throwing more money at the issue, and I want to put the stall I just got in, but I wont do it until this is fixed.
