1 - 2 of 2 Posts
Mark Phillips
Just a quick question. I'm looking to swap a 4.7 from a 04 Dakota into a 02 durango. From what I can understand. All I need to do is swap the crank and cam tone wheels. I have the 4 plug PCM in the Dakota. I haven't seen the Durango but I think it's a 3 plug.
Double check to make sure you don't have to do this swap because some 02 Dakota's and Durango's went to the 4 plug NGC controller versus the 3 plug plus TCM JTEC controller.
If the 02 Durango has the 4 plug PCM, you don't have to swap the tone rings. If it has the 3 plug PCM, then yeah, you will have to swap tone rings.
1 - 2 of 2 Posts
