21 - 40 of 61 Posts
I have 4.10 in my truck with a 28 inch tire, 4x4 with probably 30+ tires definatly do 4.56. Don't take any advice from people that don't actually HAVE gears and are just relaying what they've heard or read . My gears didn't affect my milage much if at all. City can actually get better because your not using as much gas to get going. Having said that your first 2 tanks of gas are pretty much a write off because youll Be having so much fun
Just cause i don't have them don't mean i am wrong. I have been in plenty of r/t's with 4.56s. I do not want them cause as it is i am pulling 2300 at 70 and i do a lot of freeway driving
Discussion starter · #25 ·
Yeah well though my spacer adaptor was all open butt i was wrong .it is split to keep it dual plane.so now i dont now what to do to bring the throttle response back at the bottom end.is there anyone out there that has the fi air gap whit a 4 hole throttle body on it . If yes how his it thanks
Is there anybody out there that is running the fi air gap whit a 4 holes throtle body if yes how is it
It will run like absolute shit without the head flow to support a 4bbl tb.... The 4bbl tbs flow upwards of 1000 cfm, and will KILL Any bottom end you have left...
Its about the complete combo. Putting a smaller TB on is not going to help any. Do you have a stall converter or gears? How bout headers/exhaust? Need a cam?
This.... He doesnt have any of that (to my knowledge) while a smaller tb would help a touch down low, what you sacrifice in the top end isnt worth it... You would be better putting the kegger back on for tourque and top end than put a v6 tb on the airgap....everything you gained from the top end would be gone with the v6tb
Oh yeah.... And GET A TUNE....... The timing and fuel maps are all wrong stock for a performance intake... We aint talking superchips either....SCT...... Or full standalone but i doubt you want to go that route
Ok ill start whit the 52 mm throttle body first
did you read any of what we typed you arent gonna be happy with the 52mm tb either.... you need gears, a higher stall, and a TUNE.......not a $400 tb thats gonna cut the legs off whatever bottom end you had left...
read up on port velocity and how it affects tq and power....and how changing the tb affects that.....
21 - 40 of 61 Posts
