1 - 20 of 23 Posts
1996 Viper GTS...
:drool:
stockers will need spacers...most aftermarket ones will fit no problem
pnly real down side is the overall tire height for a 335/30 tire
it already has the hotchkis drop plus the drop form a 29" tire to a 26" tire...its not too bad in person
Viperkota's truck just looks like a great example of a wheel/tire combo that's just to small for the truck.
in person its not that bad...the frame is only about 5" from the ground....if i do a 2" drop arm and a 2" hanger in the rear....i would clear most speedbumps
now granted...i am not too happy with the front wheel offset...make everything look big around it...but it does that on the viper as well
sadly, that's the only sidewall height available for that wide of a tire.
exactly....i the 17" and 18" 335....26" in pretty much it...now if you go to the 19" or 20" you can get 28" and 29" tires
but im not done with the truck yet....its overall goal is to be a friendly DD and an autocross truck
uhm, a 2/3 drop and hes probably rubbing the rear fenders.
tires= performance
and i hate to say it...but with that much sidewall and a wheel that appear to be a 17 or 18"...hes not running 335's....it has to be 295, 305 or 315 to be that tall...if thats a 2/3 drop.....hes close to a 29" tire
ok i am wrong...i checked the tire specs http://www.kumhousa.com and he could have the 335's on a 17" wheel...but hes gotta have more of a drop than a 2/3
1 - 20 of 23 Posts
