Throttle Body and Intake
3.4K views 23 replies 6 participants last post by  TurboBlew
#1 ·
Just wondering, if I get a V8 throttle body for a V6, do or should I get the V8 intake?
#3 ·
Where have you been?
It has often been declared that a popular or recommended upgrade for Magnum engines is a V8 throttle body, and seeing as the 5.2 and 5.9 throttle body is the same (from the factory), I don't think they were meaning it as an upgrade for V8 engines.
And in any case, the question was about the intake for the throttle body.
#7 ·
The reason from changing filters is because the stockers suck ass and the aftermarkets provide better flow. You don't have to move the location to notice a gain, however, moving the filter closer to the insert of the hood/grill is recommended as you arn't receiving as MUCH warm air from manifold/motor.
#6 ·
uhm.. turboblew is stating a MANIFOLD won't work on a 6cyl. A TB will as the TB mounts to the manifold. An an air filter doesn't matter in any case. A chevy air filter can work on a mopar, or a ford, or a saturn. You mis understood turboblew, an 8cyl manifold with 8 holes won't WORK on a 6cyl block with 6 holes.
#17 ·
So, does that mean that there aren't any reasonable worthwhile intakes for V6s? Stock for stock, a V6 isn't going to need as much air as a V8, but just as V8s can be modded, so can V6s.
Also, would the distance to the front fender area from the throttle body be the same for a V8 and a V6? Meaning is the throttle body the same distance from the radiator support (or any other point that both have in common)?
