1 - 10 of 10 Posts
tigers28
what shackles will work on an 01 durango slt plus 4x4
Are you looking to lift it? If so, the Belltech 6400s will give you a 2 inch lift. You should search a bit before posting questions, you'll be able to answers to a lot of your questions, and it's often quicker than waiting for a response. It's answered almost all my questions so far (I'm relatively new to the Dak-Dur world as well).
Discussion starter · #3 ·
will these belltech 6400 shackles lift or lower my durango
Discussion starter · #6 ·
but their meant to lower a chevy or gmc right
Discussion starter · #8 ·
ok thanx so i have to remove my stock tow hitch to swap them then i can put it back on right
yes.....once the longer shackles are put on, you can put hitch back on. I suggest doing more searches on the install......you'll need some washers as the belltechs are not as wide as the stock shackles....can't remember how many you'll need per side..Also, would be a good idea to spray some penetrating fluid on the torsion bolts and the shackle bolts a few days prior to make your life a bit easier.....
Discussion starter · #10 ·
ok thanx but what do u mean get washers are the shackles to big or to small
1 - 10 of 10 Posts
