He just upgraded to 65" tall tires from a tractor. He built this thing in his backyard.
there are some custom one off wheel brake kits out there for 5 tons... studlybilly did wheel brakes on his 2.5 tons for ~$600.That and I also dont think anyone makes a "disk brake kit" for 5 ton axles?
neither truck is on 2.5 tons. :nana:there 2.5 ton rockwell (military) axles. there are no brakes on the hubs it slows down the drive train rather then the wheels.
if you try and go to any big event on any DOT tire, you're just going to spend your day getting stuck.Agree!
Some people just have to much money :huh:
When you have to start buying tractor tires instead of mudders, your to big!
my truck is 10 years old.... and no, it doesn't get driven on the street.You have to have the money, if you take a 6 year old vehicle off the road for mudding only, You sure can't legaly drive that on the street.
i have been to hortense. i spent the day stuck.guy i know, lives in hortense, im sure rebel's heard of it, we have the off road park there, where they had trucks gone wild, etc. hes got a f350, idk year maybe 04 05 on 49s with the 7.3 its his DD. i can get pics off his myspc let me see.
correct... pinion brakes are illegal and unsafe for street use.Very cool! I really love the Chevy HD's of that vintage, specially Reg / Longs.
The Pinion brake is a very 'efficient' way of braking. You use the gearing to your advantage. It's also hella easier to work on (durh, only one right out in the open front and rear)
That being said, I don't believe that pinion brakes are OTR legal PERIOD. Also, full hydraulic steering is a no-no for street legality (Non 'self centering')
the black truck has too much gear, but that's only a 5 minute gear swap in the transfer case. it won't be the miracle you're thinking though....they are not geared properly, they are way to low. they hit the revlimiter in 4th gear and dont even try to spin the tires.
still BADASS trucks. i think its AWESOME to see a properly built mud truck and not one that cant flex out!! love the flexin pics.
tan truck is 5.26 in the transfer case and 6.44 in the axles.Incredibley badass! Those things are sick.
What size gear are they running anyway?
humvee's are still on the axle shaft and don't get any help from the gearing.it's that way for the same reason our military humvee's have them there. it's easiers to slow the rotation of a drive shaft down then heavey tires
having said that.... i'm still not sure why we don't use that setup on our 7 tons.... lol.
why would anyone build a mud truck with open axles?they make a kit for disc brakes on all for corners. seen it on extreme 4x4
if you break an axle you lose your brakes! unless you have a locked axle.
doubtful.... it goes anywhere anybody else does. it's too big to put on a show with horsepower, so why bother with it at all?damn fine fabrication there! needs to do some mods to that motor tho
it's a 2000 with 295,000 miles that had been worked hard, it's whole life.... it wasn't worth anywhere near 13k.What! 13k? The truck is worth more than that! How much were the tires?
He got stuck at the end cause he had no momentum and No wheelspin. Wheel speed is key. They aren't rock crawlers. I'm not saying they can't build a truck cause those are the sweetest mud trucks ive seen. Just overkill on the gearing.
the F350 is a 6.0 diesel.... both of the GM's are 6.0 gas motors. i haven't been all that impressed with the diesel trucks....Not sure if I missed it and I couldn't tell in the video but are these guys running diesels? Having a nice built diesel with 1500+ft/lbs would get those tires turning pretty easily...
the guy with the black truck had a shaffiroff 582 in his last truck.that thing is just begging for a Big Block under the hood!
my rev limiter is 6200 (efi live). i typically hold ~5500rpm in black mud. the clay will bog me down some... the black truck is still stock rev limiter.yeah.... those 6.0 are good motors.... but they need something that can hold 6k on the tack, o well... guess one step at a time....
