Not sure if this will help.
Fuel Pressure Safety Switch (FPSS)
This is a device that's plumbed into the fuel system, and provides an open or closed circuit based on availability of fuel pressure. It can be used in the triggering circuit to make sure the system isn't on when you've got a fuel problem. Typically, you only use it to switch off the nitrous solenoid; turning off the fuel solenoid as well can start a cycle of switching the solenoids on and off while the pressure raises and drops in the fuel system when you're switching the solenoid on and off. Let the pressure build up in the fuel lines when you open that solenoid, and when it's high enough, the nitrous solenoid will open. The switch can be used whether you've got a wet or a dry system. You can adjust the pressure at which it triggers by using an allen wrench on the back of the switch (loosen the screw lowers the pressure threshold).
You want to set the pressure on the FPSS, such that if the pressure drops about 10psi the nitrous system will shut off. On a wet LT1 system, this will be around 33psi, and on a dry system I'd leave the switch just above stock, say 45psi.
To set the threshold pressure, you've got a few options"
Connect enough plumbing so that you can have the FPSS installed at the same time as a fuel pressure gauge. Turn the key on to pressurize the fuel system, then turn it off. As the fuel pressure bleeds down, monitor the continuity across the FPSS contacts (disconnect them from the rest of the nitrous system) and when the pressure reaches the level you're interested in, adjust the screw on the back so it just balances back and forth between the continuity signal.
You could use an air compressor, with the appropriate fitting for the FPSS. Remove the FPSS from the car, and thread it onto the compressor. Set the compressor for the pressure of interest, and measure continuity as above.
If you can't do option #1 above because you don't have two available ports, first thread in the pressure gauge, and cycle the key. Then time how long it takes for the pressure to bleed down to the correct level. Then disconnect the pressure gauge, install the FPSS, and do the process against the clock rather than the pressure.
