I enjoy the loudness at idle, but I HAVE to get rid of this flowmaster, any opinions?
4.4K views 20 replies 11 participants last post by  Fatfenders
#1 ·
Hey guys, since I've had the truck, it's had a dumped flowmaster 40 series that just makes a TON of noise, a TON of drone. The tone is merely okay, but I'd like something that's quieter on the highway.
I recently cut my third cat out, and that made it a little worse.
I'm thinking of going with a magnaflow, but will a magnaflow dumped still continue to drone? I remember having a 14" magnaflow on my old durango without cats, and that didn't drone much, but I did have the exhaust run to the stock position.
Any recommendations as to what I could do here? Still be loud around town, but cruising speed I'd like there to be little to no drone.
Also, is it unheard of the have a pipe run out the back, but dumped at my rollpan? I love the no tip look, but I need to get the exhaust exiting away from the truck.
#2 ·
#3 ·
I have a magnaflow that is dual sent out to the rear, cat still in place and at times I think it's almost too quiet, however if you're outside the truck at idle it sounds amazing! When you accelerate it really sounds tough! I really can't decide whether I should take the cat off of it, it's my dd so I'm scared about drone in the cabin.
I would say a magnaflow is definently the direction you want to go when it comes to mufflers. Exiting the exhaust out the back or dumping it atleast behind the rear axle would help your noise. Or you could do the side exit before the passenger rear tire and throw a high flow cat on it to help.
#4 ·
go with magnaflow! I have one dumped and it doesn't drone bad at all.
Never was a fan of flowmasters, never had any complaint with my magnaflow, get complements on it all the time, a mechanic at the dodge dealer actually chased me down as I was leaving cause he had been playing with mufflers on his 4.7 ram and wanted his to sound like mine.
#11 ·
Has anyone here with a magnaflow, or flowmaster that's dumped out the back removed their cat? If so did doing so create drone and more noise inside the cab? I'm thinking of deleting my cat but am leery to do so because my R/T is my dd and I don't want anything annoying. :drive:
#12 ·
I had my magnaflow 14" with my cat removed on my durango 5.9 a year ago, it droned a little bit, but on the highway, nothing. Best sounding truck i've had. I miss it too. lol
#14 ·
I think cats do help with the resonance. I would try to dump out the side or back. Less drone and exhaust fumes. I have a Flowmaster 40 on a full exhaust and it's still obnoxious. I placed a Dynomax straight-through in front of it and it helped with the drone considerably. I put an exhaust cut-out for loud and less restriction. I would go with Magnaflow or Borla.
#15 ·
I think I'm gonna go with a single 3 I/O magnaflow and run a single 3" dumped out the back.
Duals are just for looks anyway, unless I go true.
#17 ·
I think you'll be fine with a 3" single.
#20 ·
I know that, I just want some options to choose from. Seems like straight through is the way to go for the elast amount of drone.
