1 - 8 of 8 Posts
I've got Depo crystal clear heads and corners on my truck. The quality and fitment of them is very good in my opinion, as good as OEM. They should work with your stock headlights, but you will need new bulbs for the corners. You need four 3157 and two 194 bulbs in amber for the corners because the stock bulbs are clear. Although I went out and bought new bulbs without knowing my Depos came with bulbs I needed anyways.
Discussion starter · #3 ·
the 3157 is for the blinkers/parking lights right? what is the 194 for? i dont know if these come with bulbs or not but i would have to wait until after i get them so i have money for them anyway
Stock bulbs will work with them, but they will be the wrong color. Stock housings use clear bulbs behind a amber lens. You need amber bulbs behind the clear lens. Most of those aftermarket lights come with the amber colored bulbs, however they are incredibly cheap quality and the amber color tends to fade off over time resulting in bulbs that all don't match when lit. I suggest quality Sylvania bulbs if you are going to do it.
3157 is for the two middle bulbs, and 194/168 is correct for the third outer bulb.
I run those clear corners on my '01, have for about 2 years now. They are starting to show their age.
What do you have on your black one?
I went with chrome Stealth bulbs in my corners to keep the amber from reflecting in the housings when they're off.
Discussion starter · #8 ·
Thanks guys, I'm gona order them when I get paid next Wednesday, I've seen stealth bulbs in ford super dutys that are clear when the running lights are on then turn amber with the blinker do they have these for the durangos and how do you think they would look?
Sent from my VM670 using AutoGuide.Com Free
1 - 8 of 8 Posts
