Ok so Nitto says my tires should be max inflated to 51psi...so how much do I do in lbs.? I'm confused... :huh:
I figured, and I went with 255/50-17 insteadno thats the max inflation pressure. For example the max they should reach when the tires are hot and you are beating on them. you should still go by what the vehicle calls for on the door jam or maybe just a tad more. Ours call for 35 psi when cold so I wouldnt go much above that.
PSI is what people call lbs. its pounds per square inch. Its the same thing.
What's new?...I'm confused... :huh:
what do you mean by "P rated"?I wouldnt run a P rated tire on any truck, those sidewalls are to flimsy, and ive seen em blow out for no reason.
