i have looked around and cannot find exactly what im looking for so here we go, i have a 2001 Durango 4.7 2WD and all of a sudden the trans is going into limp in mode. codes are P0732 P0734 and P0733, no other codes...... reset and test drive later on to see what it is doing, has a delayed shift into drive and then is ok, will go up to 3rd gear and then have a shift flare into it and will try to go into 4th gear and then the check engine light comes on and limp in mode........ car has 100k on it.... fluid is full and red and not burnt, slight leak at pan. just wet, no drip.... never had an issue until this morning.... only thing that changed was the weather, we went from 65 plus yesterday to 20 this morning here in Big D....... the speedo operate correctly, im down to possible speed sensors or internal trans issue.... pan has not been dropped and i took out one sensor to look and seemed ok. little debris on it... any help would be great.......
