I have an '02 Dakota SLT with the 4.7, and it has been experiencing misfires for quite some time, primarily on cylinder 4. I started with the spark plugs, then the ignition coils, then a fuel injector, and the misfire was still there. As time went on, it started running horribly, come to find out the crankshaft position sensor failed, replaced that and it for the most part started running better. It has had a head gasket leak for a while, so I recently replaced that (along with timing chain/tensioners, hydraulic lash adjusters, valve springs/seats, water pump, and various other o-rings and seals), and the coolant leak went away.
When I had the valves cover off, I noticed the rocker for C4 was off- replaced all valve springs and seats so... misfire fixed... right? Nope.
It is still reading misfires on 4-8, and I am stumped. The timing is perfect, and it runs really well, apart from a check engine light. Also can't feel it running as if that many cylinders were gone. I was thinking of replacing the camshaft position sensor yet... but wouldn't a fault there cause all cylinders to run badly?
The sparks are working because the pistons aren't entirely dead and being thrown around, also there is a normal amount of charing on all the spark plugs.
Again, the truck doesn't run violently as if over half the engine wasn't working, but it is an annoying dash light and can tell something is wrong.
I am quite lost; anything helps.
