1 - 20 of 79 Posts
realdeal7369
· G.F.Y racing president
I had this thread posted in the bad news section and finally had a chance to post it here....
I wrecked my baby on the way home from work 1/31/14. Front end is smashed..passenger side is fucked. It has the 5.2L engine..level ten trans. And level ten rebuilt rear with 4.10 gears..new bearings and seals. Interior is in great shape..driver side is good shape except the front fender which was hurt in a previous accident before I bought it back in 2006. If anyone needs parts for their truck...please email me..realdeal2911@yahoo.com
I'm also looking for an rt cc too. I want to swap what parts I have that I know will work on it. Like my hotchkis suspension and some various other parts...
Everything else needs to go. Motor has 148000 miles on it..ran like a top. Trans has a years worth of milage..roughly 12000 miles. Rear has slightly less..and has no noise issues either.
Let me know what you need. Parts are sold as is. Shipping will be an added cost..unless your local...then if that's the case we can meet up. Some of the items I have are listed inmy signature too..
All the glass is good except the front windshield.
Brakes are good. Front rotors are cross drilled and slotted.
Master cylinder is in excellent shape.
Brakes lines are good.
Fuse block s sold...
Drivers side door lock and window switch is sold.
Have some parts foe sale on eBay too...please check them out...(im jamesd9028 on eBay.)
Thanks
Jim
How hard of a hit did it take? How much for trans? Are you capable of shipping it?
Would cost me 6500.00 to fix it. Trans I'm looking for 2500.00...obo..shipping on it I have no real way to do it....trans has a prototype valve body in it where pat barret of level ten was experimenting with better fluid flow and all that. We have the line pressure at about 70-75..as apposed to the stock 110-120 (I think it is)....chirps second very nicely..third gear is just as crisp..so is overdrive. I would need some time to get it out...everything is still in the truck.
Wow, what was the price new and what all is done to it? I thought they were $2500 from Level Ten
Discussion starter · #6 · (Edited)
Cost me almost 4000.00 . Has 2400 stall. Upgraded bands..clutches..etc. prototype valve body...also have a trans cooler that will go with it. Lines too if anyone needs them. I just want to gut this truck out as best I can before I scrap the shell and frame.
Anyone interested in the rear?..it has an lpw diff cover. Royal purple gear oil in it. New bearings/races..and new seals throughout. I paid 1800.00 for the rebuild (parts included)..Richmond gear 4.10 posi unit too. Brake drums are in good shape..so are the brake components too.
Also have a painted (gloss black and cleared) driveshaft. U joints are good on it...shoot me an offer.
Truck is a reg. Cab. Short bed (6.5' bed)....
$2500 is out of my league lol.
Sorry...but its got 4000.00 worth of parts and labor in it.....best I'd go is 2200. Plus shipping
I'm not saying it's not worth the price, just saying that the price is out of my league. I'm sure it is a bulletproof unit, but my budget doesn't allow for bulletproof. My budget is used junkyard trans, but I am making it allow for quality reman'd unit lol.
Bump
Discussion starter · #14 ·
How much for the rotors shipped to 65721
Be fore warned...these have been sitting For a while and have some rust scale on them...they should clean up though...they aren't warped or anything like that......
Pm me ..let's talk about pricing and shipping...
Discussion starter · #15 ·
Discussion starter · #16 · (Edited)
Items I have yet...
5.2L......650.00
44re custom trans with 2400 stall......2400.00
Rebuilt rear with 4.10 gears..auburn differential..new bearings..races and seals.....950.00
B&m trans cooler.....25.00
Stinger 1700 battery.....may keep this for my magnum if it fits...either way I'll have a good sided battery to sell...lol
aero turbine 3030 muffler and custom exhaust (over the frame and exits in front of the rear tire 3" pipe)
Msd wires.....25.00
Reflashed and updated p.c.m. ..has been upgraded further with an SCT programmer
...would like to sell both of these together...I have no way to unlock the pcm from the program I loaded onto it..unless someone has a simulate year truck...then I could do it...
steering rack and pinion.....60.00 (used total purple power steering fluid in it..works like new)
New grille..(painted in grey primer).....25.00
Front energy suspension control arm bushings (new).....40.00
Front energy suspension greasable style sway bar bushings with hardware (new)...in 25mm....35.00
30mm.....35.00
New bilstien shocks (in box)....100.00 for the pair..(for the front)
Control arms....60.00 for all 4....
Steering knuckles....60.00..for both
Front wheel bearings (one I have is new in the bag..the other is about 6months old)
Tie rod ends....10.00
Throttle cable
Full interior:
dash..........................300.00
door panels.............200.00pr...100 each (modified for tweeter placement)
steering column.....300.00
seats..............250.00
carpet............80.00
Headliner.....80.00
glove box....35.00
rearview mirror.......10.00
New heater core..(less than a.year old)......25.00
Various stereo equipment:
Pioneer 4x6 speakers in a custom plate I made for the back corners......60.00 pr
200 watt 8" bazooka tube...........................200.00
phoenix gold tantrum8 sub woofers.........40.00 each..(I have two)
super crew sounds dual 8" sub box.........140.00
pioneer FM satellite tuner...........................30.00
Modified stock fuel rails for AN type fittings..
Stock fuel rail
Stock injectors
Fuel line
Gas tank
Filler neck
Black coated aluminum fuel door...10.00
Slider back glass
Driver side door (fully dynomated).....300.00
Drivers side door internals
Driver side street scene rear view mirror....20.00
Street scene roll pan.......100.00
Tailgate........150.00
Spare tire winch......20.00
Full size spare wheel with tire (never been used it seems...tread is still 100%..but will.not hold air)......30.00...(looking for local buyer if possible)
bed (passenger side damage)..has line x spray done by previous owner....bed floor and sides are fine...the outer skin on passenger side has the damage....(local buyer if possible)...would make for a good trailer type thing for those who need to haul stuff..
passenger door glass.................40.00
Passenger door internals..........name what you need..I'll get it for you.
Rt wheels with nitto tires..........................................................650.00 obo
baer decela rotors..............................................................50.00 for the pair
Calipers................................................................................20.00 for the pair
Front Brake lines.................................................................10.00pr
Rear brake lines....................................................................15.00pr
Intermediate brake line...(runs from master cylinder along the frame....60.00
Abs module (I think its called..)..brake lines run to it..then off to the brake calipers and wheel cylinder...40.00
Rear wheel cylinders...............................................10.00 each..15pr
E brake cable.................................................................................60.00
Black painted and cleared driveshaft..........................................50.00
Engine wire harness...................................................................make offer.....
Front end wire harness (for lights and various other things)
Night shaded tail lights........35.00
Rear wire harness
Rear tail light bulbs....................................10.00..(complete set)
Headlight bulbs.........................................10.00....I have three or four..I'll send what I have
Hid kits and bulbs...
Probably forgot a bunch of things....will list them as I take them off....anyone need anything..please let me know...email me at realdeal2911@yahoo.com....
Anyone know of anyone selling a touchscreen factory navigation head unit for 2005-2007 dodge magnum...id be willing to trade parts for it.
Also looking for magnum or challenger wheels (aluminium.....not chrome)..again willing to trade parts and add cash if needed.....
Discussion starter · #17 ·
Valve covers and h.s. roller rockers are sold.....I still have the Mopar adjustable 1.6 roller rockers for sale....less then 3000miles on them....anyone interested shoot me an email...
Discussion starter · #19 ·
Bump....parts listed and then some are still available.....anyone local to me need anything?
Anyone?
1 - 20 of 79 Posts
