Have a few pics of my 08 intake install. Haven't even started it up yet. It took me 3 months to get it installed, working 65-75 hours a week is rough!
Thanks man! I was planning to keep this thing stock but that didn't happen. I currently have HO cams, ASP underdrive pulley, 08 intake, ported TB, Superchips programmer, Jeep TCM, 4.10 gears, ceramic coated headers, mangnaflow cats, magnaflow cat back exhaust. Typical "stock" truck LOL...Looks good dude. You are going to love it. What other mods do you have done?
First you'll need to buy/make an adapter plate to mount your existing throttle body to your new 2008+ intake manifold (that's a whole other discussion)Okay I need a run down of what you did for the swap. What was in the way, what hoses had to be moved, ect.... Details man!! lol Step by step is what I'm looking for.
My JTEC 4.7 with intake/exhaust/TB would run low 11s AFR above 4500 rpms on stock tune.I think the stock ngc ecu in my 2003 durango is more prone to running lean than the jtec ecu.
Wow, that should be fat enough to support (mostly?) the 2008+ intake. On my NGC 4.7 with the 2008+ intake I'd see the A/F ratio go leaner than 14.7 above 4500 rpms!!! I need to get a wideband O2 on there to see what's really going on, even with my SCT tune.My JTEC 4.7 with intake/exhaust/TB would run low 11s AFR above 4500 rpms on stock tune.
My 2003 Dakota and 2006 Ram with the 4.7 BOTH ran rediculously lean up until catalyst overheat protection kicked in, even bone stock. They ran ~14.7:1 up until 75-90 mph and then the overheat brings it down to 10.5:1 af. They both picked up 2-3 tenths in the 1/8 mile alone by eliminating the WOT Fuel Delay, something Superchips does not do. Even on stock tune just eliminating the WOT fuel delay, with HO Cams or 218 cams, 2008 intake, and Headers the WOT fuel dropped close to where it needed to be around low-mid 12s.Wow, that should be fat enough to support (mostly?) the 2008+ intake. On my NGC 4.7 with the 2008+ intake I'd see the A/F ratio go leaner than 14.7 above 4500 rpms!!! I need to get a wideband O2 on there to see what's really going on, even with my SCT tune.
Thats the one..I need some help guys. I'm installing my 08 intake now on my 01. Is the intake temp sensor the one that is on the drivers side of the 01 intake on the runner? Is that the one that was stated in an earlier post to move it to the cold air intake? Any help will be appreciated.
