Forsale
1995 Dodge Dakota
130,000 miles on body
360 magnum with nv3500 5 speed
Engine
MPI Magnum 5.9L Short Block #5007549 $1143.10
Mopar M1 2bbl MPI Single Plane Intake #5007398 $241.36
Mopar 1.6 Roller Rocker Arm Package #5249800 $242.20
Mopar "Thin" Vibration Damper #5007187 $110.00
Hughes Engines Cam #HER1828AL $187.50
Hughes Engines Matching Valve Springs #1110 $64.00
Heads Dipped and Bowl Ported With Valve Job By Koffels Place $435.00
With Ports Polished By Previous Owner
Centerforce Dual Friction Clutch Package $317.73
Junkyard Magnum 360 Flywheel With Turning $200.00
Quick D 52MM Throttle Body(Thanks Mike D) $175.00
Mopar Headers
Mopar Valve Covers
MSD Wire Set With Blaster Coil
Mopar Underdrive Pulleys
Hughes Engines cam # HER1828AL, it's specifications are a .544 lift
for both intake and exhaust with a duration of 218° intake and 228° exhaust @.050
3” single exhaust from Y pipe to over the rear axle
Small oil leak from oil pan
Body
Black exterior
Fiberglass roll pan
Spray/Roll-in style bed liner
Soft tonneau cover
Removed Emblems
Rust down low on front bumper where valance attaches
Looks like one or two panels have been painted before
Paint is a 6-10 in my opinion it shines, fairly clean body, but to be perfect I would paint it
Interior
Gen 2 factory Gray Bucket seats
Gen 3 center console
Aftermarket clean carpet
Clean dash
Recovered headliner
Power Window
Power Locks
Remote Keyless Entry
20% tint on all windows by Ziebart
Rear End
8 Âľ B Body rear-end
3.90 gears
New Rear linings & Hardware kit
New Axle seals
Trans
NV3500
Front end
Newer Ball joints
Poly–urethane front suspension bushings
Repainted front suspension components
Bell tech lowering spindles 2"
Recently clean, adjusted, and packed front wheel bearings
This is a strong running truck. I drove it on several 3 hour road trips one way, and drove it daily in nice weather. It gets about 17 mpg with me driving, but that can range depending on driver. It has run 13.60-13.70 on street tires with me driving with 2.0 60 ft times. It had 104 mph trap speed, so the 60ft it killing the ET.
I think it could run low 13’s with slicks if it hooks.
The paint is fair and respectable, but if you wanted a perfect truck, then in the future you might want to have it repainted
I have a different truck and need to sell one of them. If you are serious about it PM me on here.
This truck was bought off a member, here and was very upfront about the truck. It is a great truck!
6250 obo with the wheels. i can sell it without wheels for less.
Brand new tires have less than 3000 miles on them (Nittos)
The cowl hood does not come with the truck.
More pics available upon request.
1995 Dodge Dakota
Engine
Mopar Headers
Mopar Valve Covers
Body
Black exterior
Fiberglass roll pan
Soft tonneau cover
Removed Emblems
Interior
Clean dash
Recovered headliner
Power Window
Power Locks
Rear End
3.90 gears
New Axle seals
Trans
NV3500
Front end
Newer Ball joints
