ok so can anyone really tell me what my code is P0420(catalyst system efficincy below threshold(bank 1) Thanks!
but couldn't that allso be just a O2 sensor???Basically it is telling you that the catalytic converter is junk.
Cats aren't meant to last a lifetime. WHile it is good advice to have the vehicle checked to make sure that it is in fuel control so a new cat doesn't get burnt up it by no means means that the old cat failed due to a running issue.O2 sensor is working...it's ranging the same as the front O2, it's telling you that the cat has degraded enough so it cannot do it's job efficiently, your cat is dead and now you will have to find out why and correct it before you put another cat on. If you don't find the problem, you will destroy another cat
:bs2:I read this on another board and it doesn't cost much and may get you through for awhile. Get a bottle of HEET or similar, it's all alcohol anyways, and take off one of the vacuum hoses. Insert that hose into the bottle and with the engine running let the vacuum pull suck the bottle dry. You regulate the flow with a pair of pliers to avoid some extreme detonation. Go and clear the code and drive it.
The alcohol is supposed to break up whatever is causing the clog in the cat.
:waiting::jester:I read this on another board and it doesn't cost much and may get you through for awhile. Get a bottle of HEET or similar, it's all alcohol anyways, and take off one of the vacuum hoses. Insert that hose into the bottle and with the engine running let the vacuum pull suck the bottle dry. You regulate the flow with a pair of pliers to avoid some extreme detonation. Go and clear the code and drive it.
He is already out by time not mileage, if he is under the 80k. You only get 8 years OR 80k on emissions. It really depends on the in service date, but back then vehicles were not sitting for 6-12 mo on the lot like they are now, unless it was poorly optioned.If by chance you have less than 80K on your truck, take it to the dealer and get it replaced for free under the Federal Emmission Warranty. If it's over 80K then the cost comes out of your pocket.
