1 - 9 of 9 Posts
MrBuzzard
Ok i'm having a trouble understanding the whole concept behind what injectors to use. The stock injectors on a 98' 5.2L are 19lbs @ 49 psi right? or did i miss read? I have used the search bar and have read ALOT of different topics but none have seem to clarify what i need to know.
I'm getting my 408 from JM in a few months and i was wondering what injectors i should run and at what pressure?
Thanks in advance! I've just been stuck for a few days haha.
Discussion starter · #2 ·
anyone? lol
Your stock fuel pump should be more than enough to supply the fuel pressure you'll need for the 408. As far as the injector size, I'd check with John and ask him for his recommendation on that since he's the engine builder.
thanks dak and dodge, John said i wouldn't really need 32lbers but then he said 24lbs will be fine but the engine needs to be making the right amount of horsepower, So i'm a little confused.
B&G will be doing the flash, i could just run 24's and tell him not to go to rich on the fuel side due to emissions and stuff right? Any recommendations on which injectors to go with?
Thanks again guys
Thanks again guys
B&G ?
Ouch....!
I had three flashes done on mine with those guys, they never did get it right.
Get a SCT from Hemifever...Let him do it.
Does hemifever have a site? I know he's on alot of these forums. Or do i just drop him a PM?
1 - 9 of 9 Posts
