1 - 8 of 8 Posts
suprchgd99rango
· Pre-Teen Giggle Brigade
little confused. put the trans and transfer case in.
no overdrive, sometimes wont start in park. do we need to adjust linkages? im confusedddddd
Put it in park, then disconnect the rod and see if it is fully .seated in park. Will it start in neutral?
ok so i decided to try my old pcm (5.2) on the truck (5.9) after a suggestion from a friend and i had OD but it said no bus. still ran and drove fine. then CEL came on, no code. then i got an exhaust leak by the header...i swapped pcm back and checked for codes altho no CEL and i got p0351- Ignition Coil A Primary/Secondary Circuit Malfunction
what da fack.
1 - 8 of 8 Posts
