would you gain any performance out of it? or would it just be pointless?
Jake brakes are different than exhaust brakes (exhaust brakes are the only kind found on pickups). The reason diesels need the help is they do not have a throttle valve like a gas engine. So an exhaust brake is the oppsite of a throttle valve, it is more effective because restricting the exhaust flow slows the engine more than restricting the intake (vacuum vs pressure). An exhaust or jake brake would actually work on a gas engine but there isn't as much of a need for one plus to actually make it effective the throttle would have to be opened, complicating things.I am assuming that diesels have a varying amount of backpressure when compared to gas engines.
That's why Jake brakes work on diesels, but not on our trucks.
thanksJake brakes are different than exhaust brakes (exhaust brakes are the only kind found on pickups). The reason diesels need the help is they do not have a throttle valve like a gas engine. So an exhaust brake is the oppsite of a throttle valve, it is more effective because restricting the exhaust flow slows the engine more than restricting the intake (vacuum vs pressure). An exhaust or jake brake would actually work on a gas engine but there isn't as much of a need for one plus to actually make it effective the throttle would have to be opened, complicating things.
A mufler is a muffler. A "diesel" muffler is just a muffler with a "big" inlet/outlet.
Doesnt Sidewinder have a diesel exhaust? or is there another red dakota Im thinking of?
that would be me. there is no difference, just bigger.Doesnt Sidewinder have a diesel exhaust? or is there another red dakota Im thinking of?
Define "diesel" muffler :waiting:so, what your saying is that the flow of a diesle muffler will be the same as the stock muffler i currently have?
Ok. I knew it was a badass truck, been a long time since I saw the exhaust pics:mullet:that would be me. there is no difference, just bigger.
not even close.so, what your saying is that the flow of a diesle muffler will be the same as the stock muffler i currently have?
diesel muffler being a muffler from a ram 2500, would it flow better or worse? i ask all of this because im wanting a better flowing exhaust, but i dont want the loudness of it all, i want to keep it looking and sounding as stock as possible so when i roll up on some fool and then smoke his ass, he is dumbfounded and left eating my dust...
not necessarily true, it depends on the engine. These magnum v8s are bit different. It seems that can't go too big on the exhaust or intake tracts, with the mgnum v8s.I would not run one of those 4 inch( or larger) inlet/outlet systems..
Gas engines like a little back pressure..
And its not great for your valves..
