HARSH ENGAGEMENT
(FROM NEUTRAL TO
DRIVE OR REVERSE)
1. Fluid Level Low 1. Add Fluid
2. Throttle Linkage Misadjusted 2. Adjust linkage - setting may be too long.
3. Mount and Driveline Bolts Loose 3. Check engine mount, transmission mount,
propeller shaft, rear spring to body bolts, rear
control arms, crossmember and axle bolt
torque. Tighten loose bolts and replace
missing bolts.
4. U-Joint Worn/Broken 4. Remove propeller shaft and replace
U-Joint.
5. Axle Backlash Incorrect 5. Check per Service Manual. Correct as
needed.
6. Hydraulic Pressure Incorrect 6. Check pressure. Remove, overhaul or
adjust valve body as needed.
7. Band Misadjusted. 7. Adjust rear band.
8. Valve Body Check Balls Missing. 8. Inspect valve body for proper check ball
installation.
9. Axle Pinion Flange Loose. 9. Replace nut and check pinion threads
before installing new nut. Replace pinion gear
if threads are damaged.
10. Clutch, band or planetary
component damaged.
10. Remove, disassemble and repair
transmission as necessary.
11. Converter Clutch Faulty. 11. Replace converter and flush cooler and
line before installing new converter.
DELAYED ENGAGEMENT
(FROM NEUTRAL TO
DRIVE OR REVERSE)
1. Fluid Level Low. 1. Correct level and check for leaks.
2. Filter Clogged. 2. Change filter.
3. Gearshift Linkage Misadjusted. 3. Adjust linkage and repair linkage if worn or
damaged.
4. Torque Converter Drain Back (Oil
drains from torque converter into
transmission sump)
4. If vehicle moves normally after 5 seconds
after shifting into gear, no repair is necessary.
If longer, inspect pump bushing for wear.
Replace pump house.
5. Rear Band Misadjusted. 5. Adjust band.
DN 42/44RE AUTOMATIC TRANSMISSION 21 - 51
DIAGNOSIS AND TESTING (Continued)
CONDITION POSSIBLE CAUSES CORRECTION
6. Valve Body Filter Plugged. 6. Replace fluid and filter. If oil pan and old
fluid were full of clutch disc material and/or
metal particles, overhaul will be necessary.
7. Oil Pump Gears Worn/Damaged. 7. Remove transmission and replace oil
pump.
8. Governor Circuit and Solenoid Valve
Electrical Fault.
8. Test with DRB scan tool and repair as
required.
9. Hydraulic Pressure Incorrect. 9. Perform pressure test, remove transmission
and repair as needed.
10. Reaction Shaft Seal Rings
Worn/Broken.
10. Remove transmission, remove oil pump
and replace seal rings.
11. Rear Clutch/Input Shaft, Rear
Clutch Seal Rings Damaged.
11. Remove and disassemble transmission
and repair as necessary.
12. Regulator Valve Stuck. 12. Clean.
13. Cooler Plugged. 13. Transfer case failure can plug cooler.
NO DRIVE RANGE
(REVERSE OK)
1. Fluid Level Low. 1. Add fluid and check for leaks if drive is
restored.
2. Gearshift Linkage/Cable Loose/
Misadjusted.
2. Repair or replace linkage components.
3. Rear Clutch Burnt. 3. Remove and disassemble transmission and
rear clutch and seals. Repair/replace worn or
damaged parts as needed.
4. Valve Body Malfunction. 4. Remove and disassemble valve body.
Replace assembly if any valves or bores are
damaged.
5. Transmission Overrunning Clutch
Broken.
5. Remove and disassemble transmission.
Replace overrunning clutch.
6. Input Shaft Seal Rings Worn/
Damaged.
6. Remove and disassemble transmission.
Replace seal rings and any other worn or
damaged parts.
7. Front Planetary Failed Broken. 7. Remove and repair.
NO DRIVE OR REVERSE
(VEHICLE WILL NOT
MOVE)
restored.
Misadjusted.
2. Inspect, adjust and reassemble linkage as
needed. Replace worn/damaged parts.
3. U-Joint/Axle/Transfer Case Broken. 3. Perform preliminary inspection procedure
for vehicle that will not move. Refer to
procedure in diagnosis section.
4. Filter Plugged. 4. Remove and disassemble transmission.
Repair or replace failed components as
needed. Replace filter. If filter and fluid
contained clutch material or metal particles,
an overhaul may be necessary. Perform lube
flow test. Flush oil. Replace cooler as
necessary.
5. Oil Pump Damaged. 5. Perform pressure test to confirm low
pressure. Replace pump body assembly if
necessary.
21 - 52 42/44RE AUTOMATIC TRANSMISSION DN
6. Valve Body Malfunctioned. 6. Check and inspect valve body. Replace
valve body (as assembly) if any valve or bore
is damaged. Clean and reassemble correctly
if all parts are in good condition.
7. Transmission Internal Component
Damaged.
7. Remove and disassemble transmission.
needed.
8. Park Sprag not Releasing - Check
Stall Speed, Worn/Damaged/Stuck.
8. Remove, disassemble, repair.
9. Torque Converter Damage. 9. Inspect and replace as required.
SHIFTS DELAYED OR
ERRATIC (SHIFTS ALSO
HARSH AT TIMES)
1. Fluid Level Low/High. 1. Correct fluid level and check for leaks if
low.
2. Fluid Filter Clogged. 2. Replace filter. If filter and fluid contained
clutch material or metal particles, an overhaul
may be necessary. Perform lube flow test.
3. Throttle Linkage Misadjusted. 3. Adjust linkage as described in service
section.
4. Throttle Linkage Binding. 4. Check cable for binding. Check for return
to closed throttle at transmission.
5. Gearshift Linkage/Cable
Misadjusted.
5. Adjust linkage/cable as described in service
section.
6. Clutch or Servo Failure. 6. Remove valve body and air test clutch, and
band servo operation. Disassemble and repair
transmission as needed.
7. Governor Circuit Electrical Fault. 7. Test using DRB scan tool and repair as
required.
8. Front Band Misadjusted. 8. Adjust band.
9. Pump Suction Passage Leak. 9. Check for excessive foam on dipstick after
normal driving. Check for loose pump bolts,
defective gasket. Replace pump assembly if
needed.
NO REVERSE (D RANGES
OK)
1. Gearshift Linkage/Cable
Misadjusted/Damaged.
1. Repair or replace linkage parts as needed.
2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
3. Rear Band Misadjusted/Worn. 3. Adjust band; replace.
4. Valve Body Malfunction. 4. Remove and service valve body. Replace
valve body if any valves or valve bores are
worn or damaged.
5. Rear Servo Malfunction. 5. Remove and disassemble transmission.
Replace worn/damaged servo parts as
necessary.
6. Direct Clutch in Overdrive Worn 6. Disassemble overdrive. Replace worn or
damaged parts.
7. Front Clutch Burnt. 7. Remove and disassemble transmission.
Replace worn, damaged clutch parts as
required.
DN 42/44RE AUTOMATIC TRANSMISSION 21 - 53
HAS FIRST/REVERSE
ONLY (NO 1-2 OR 2-3
UPSHIFT)
1. Governor Circuit Electrical Fault. 1. Test using DRB scan tool and repair as
required.
2. Valve Body Malfunction. 2. Repair stuck 1-2 shift valve or governor
plug.
3. Front Servo/Kickdown Band
Damaged/Burned.
3. Repair/replace.
MOVES IN 2ND OR 3RD
GEAR, ABRUPTLY
DOWNSHIFTS TO LOW
1. Valve Body Malfunction. 1. Remove, clean and inspect. Look for stuck
1-2 valve or governor plug.
2. Governor Valve Sticking. 2. Remove, clean and inspect. Replace faulty
parts.
NO LOW GEAR (MOVES IN
2ND OR 3RD GEAR ONLY)
1. Governor Valve Sticking. 1. Remove governor, clean, inspect and repair
as required.
2. Governor Circuit Electrical Fault. 2. Test with DRB scan tool and repair as
required.
3. Valve Body Malfunction. 3. Remove, clean and inspect. Look for
sticking 1-2 shift valve, 2-3 shift valve,
governor plug or broken springs.
4. Front Servo Piston Cocked in Bore. 4. Inspect servo and repair as required.
5. Front Band Linkage Malfunction 5. Inspect linkage and look for bind in linkage.
NO KICKDOWN OR
NORMAL DOWNSHIFT
1. Throttle Linkage Misadjusted. 1. Adjust linkage.
2. Accelerator Pedal Travel Restricted. 2. Verify floor mat is not under pedal, repair
worn accelerator cable or bent brackets.
3. Valve Body Hydraulic Pressures Too
High or Too Low Due to Valve Body
Malfunction or Incorrect Hydraulic
Control Pressure Adjustments.
3. Perform hydraulic pressure tests to
determine cause and repair as required.
Correct valve body pressure adjustments as
required.
4. Governor Circuit Electrical Fault. 4. Test with DRB scan tool and repair as
required.
5. Valve Body Malfunction. 5. Perform hydraulic pressure tests to
required.
6. TPS Malfunction. 6. Replace sensor, check with DRB scan tool.
7. PCM Malfunction. 7. Check with DRB scan tool and replace if
required.
8. Valve Body Malfunction. 8. Repair sticking 1-2, 2-3 shift valves,
governor plugs, 3-4 solenoid, 3-4 shift valve,
3-4 timing valve.
