681 - 700 of 949 Posts
do those pistons have any markings on the top of them?
Discussion starter · #686 ·
what compression ratio you shooting for now?
We actually got started measuring all that last night but ran out of time.
I was told that old setup was 8.2-1, but Tracy is going to measure everything and find out for sure.
is this truck running yet or what :stirthepo
i told you i had a set still in the box.
Discussion starter · #697 ·
If anyone is still paying attention...
Motar is back together after new heads, gaskets and lifters.
new stock motor mounts are in, turbo kit should be bolted back up and all that is left is build a mount for the PS, connect/fab pipesfor the turbo outlet to the IC, and finishing the exhaust from the DP to the muffler.
You mean that's all until you decided something else needs replacing...:funny:
i thought you were going to run solid engine mounts? isn't the turbo a little close to the inner fender?
