i know a couple people on here run a four barrel throttle body. which one did you guys use? what did you have to do to get the sensors to work with the computer or do they use the same sensors as the stock one?
I'm using an Indy intake, but they both use the standard 4150 bolt pattern. Sounds like the one you were looking at with the two big blades is the Accel 1bbl tb, flows 1550cfm.Bad, your intake is an M1 right?
Is the bolt pattern for these the same as a Victor? Are they all square bolt pattern or whatever they call it?
Now I'm looking for your older thread again. I think the next post down showed some monster looking 4BBL TB but it wasn't quite 4BBL. Looked like it was two giant rectagular blades with nothing in between.
I think it began with an M -
killin' me, I just saw that post an hour or so again but I'm having trouble finding it.
i know the one i had, had the mopar stuff on it. just get the stock sensors. looked like it worked fine to me. i bought it off ebay, and was told it came off a truck, that they later turned it over to carbed. the guy that bought the truck this setup was for, didnt know much about it, only that it was on the truck, and ran like that for a little while till they swapped it out for a carb setup...guess they werent to keen on getting with the computer controls and whatever...lolRealDeal,
Looks like accufab uses GM stuff per their site. So that stuff is adaptable to our Mopar systems?
:jester::jester::jester:Oh I got ya .... problem with reading at work sometimes my brain isnt all the way here. LOL
