41 - 60 of 124 Posts
how was yours acting before the new coil?
i work 2nd shift, so a little before i would punch, i would go start the truck. when i would come back outside it was idling like shit. pop, pop, run, pop, run, etc. smelled very strong odor of gas as well...:huh:
Discussion starter · #42 ·
what about interferance using the taylor wires? is there any? also what is a good cap and rotor?
I use the Borg Warner Select, I find them at O'Reilly's. IIRC they didn't list them for the Dakota, you have to use Ram.
Brass inserts, reasonably priced.
Reactions: Silver Bullet
Discussion starter · #45 ·
thanks guys!
Discussion starter · #46 ·
i ordered wires, cap, rotor, and wire loom...:mullet:...HOPE ITS THE FIX!
Reactions: 9t9-5.2
and im not just asking darren...do any of you have suggestions for cap & rotor? also should i go ahead and swap out the coil? how hard is it to swap out the coil?
NAPA cap and rotor works just fine....just make sure whatever you use has brass contacts. and swapping a coil is SUPER easy, one wire(top), one plug(bottom) and slide it off. :eek:nethumb:
Discussion starter · #48 ·
yeah i know i changed the cap and rotor on my 88 dakota yesterday, it was way easier then i remember!
mine is running good now, but i think i still might do the cap and rotor too.
want to sell that 88 dak?
Discussion starter · #50 ·
lol...it could be arranged...y? no rust at all!
Discussion starter · #51 ·
i dont know if mine is a bad coil...it doesnt sound like its anything close to acting as bad as yours did...im hopeing the parts i ordered do the trick!
Discussion starter · #53 ·
RC, 3.9, long bed, no rust at all on the body...seriously...130k(low miles for an 88) & rebuilt trany... its a dark blue color, you can see it in the cruise to the lake thread...
Discussion starter · #56 ·
bahh. i'm at work, can't see the pics. long bed though...ehh.
yeah...i like that its a long bed tho because its my work truck:huh:
Discussion starter · #57 ·
ok so my truck now has an accel cap and rotor, taylor wires, taylor wire looms, and new plugs, and tho the idle is a little better it still misses. the thing is, I may stop at one stoplight and it will miss and the next light it might not miss. I can adjust timing with my flashpaq, is it a timing issue, or is there some sort of timing sensor that is going bad? i really dont think its a coil issue.
THANKS!
so i looked at your sig, nothing is mentioned about an M1 or Hughes intake plenum gasket kit. make sure you do either one of those, because my new spark plugs are already starting to get fouled a little bit. i'm putting in the Hughes kit hopfully Saturday. just don't want you to put all those new goodies on, then the plugs will foul again.
Discussion starter · #59 ·
it sais M1 in my sig dude...
you should put spaces inbetween words and commas...:jester:
