very soon i'll be buying a set of beeffy iron heads for my 3.9 to have ported.
should i spend the extra money to have them CNC machined or have a local dude do it without the CNC?
also, I want to get more lift out of the valve train (without getting a new cam) if it gains me more powaaa. My current cam profile is 208*/214* .512"/.520" (at 1.6 ratio which i have) on a 114 LSA, if i ditched the 1.6 rockers and went with 1.7s with stronger springs, that would significantly increase my lift, but i was told i would need to check my piston to valve clearance. how would i do that once the heads are off? and would that hassle be worth it if any? as in the power increase from the higher lift?
thank dudes.
thank dudes.
