Is the transgo shift kit a waste of money if you have suprechips? I've heard that you cant install the two together, or to just leave the resistor out. If so what does the rest of the kit do?
I've had both the Superchips and TransGo shift kit. I suggest ditching the Superchips and doing the TransGo, as that's what I did and I'm much happier.
Its that much better without the superchips? What makes it better? Seems like it would be better with both.
I personally think it is. The fact that you can remove the torque management manually and add the TransGo shift kit makes the shifting much harder than stock. Remove your Superchips, add the the TransGo, and see how you like it. Then do the TMR mod and see how you like it then. I'm pretty sure you'll want to sell your Superchips like I did afterward.Its that much better without the superchips? What makes it better? Seems like it would be better with both.
i know this is a different setup, v6 and 42re was for me, but with the shift kit first in i could actually bark 2nd and loved it over the SC but the 45s are built better and stronger then the 42-44-46s so really y not have all 3 with your 4.7? added preformance for the motor from SC and better shifting with the shift kit.
