iam thinking about doin a 4bt cummins swap into my 94 dakota and i was wonderin if anyone has done it
It be both neat, fuel friendly and rediculously slow. Go for it!iam thinking about doin a 4bt cummins swap into my 94 dakota and i was wonderin if anyone has done it
Why would it be slow? I know diesels rev lower than gas engines (which, given the same tranny with the same ratio(s) would equal a lower top end speed), but they (diesels) put out a deal more torque (which should increase acceleration given the same tranny with the same ratio(s), right?)It be both neat, fuel friendly and rediculously slow. Go for it!
About how much would you say the 4BT weighs? What about the 3.9 V6?that was a 6 cyl cummins and it was very fast if you could build the suspension to handle the weight of the 1200 lb. 6BT it would be a huge step up from a v8 but the 4 bt is adequate power and awesome gas milage, it has around 300 lbs of torque i'm sure you could shove 4-500 lb ft tq. no prob from it if you wanted it to.
We're headed that way, and it won't be long before many mainstream vehicles have diesels in them. The big problem with them right now is passing emissions. Cleaner diesels are coming out, and when they do they'll be smaller and more powerful.IMO, all auto makers should switch to diesel for cars and trucks.
The 4bt is not the best in the world, but by no means a piece of crap. Stock they are not anything special. But with a few bolt-on's you have a decent amount of power. A lot of items for the 6bt will work on the 4BT. As far as manual trans, all you need is an adapter place or bell housing. As for auto trans a lot of them had th350/400's behind them in the step-van's. The 4BT is a more versatile solution due to the fact that it WILL FIT in the engine compartment, and you don't have to fab the whole front end for it. Sure it doesn't have all the power of a 6BT, but for what it is worth, they get reasonable mileage and have power.yep slow. Unless you're making your own performance parts you're pretty well screwed for aftermarket support. You'll be using a 4 speed from the donor bread truck (most likely) and your top speed will be @75 mph. To do the swap right you'll probobly be 5g's into it before it is up to the performance level your truck now has. If you're to do this at all go for the 6bt because you have factory dodge parts support (buy a wrecked ram with teh 5000.00), the cost will be cheaper initially and you'll exceed the gas performance from day one. Your miliage will be better....etc I could go on for days. The 4bt is a worthless lump.
