Today i put my truck up on the dyno for a dyno day at a local shop, found some kinks that i got fixed and well it was worth every second of time.
first pull made 428hp/434trq @ 10.32 psi
found a boost leak at the carb hat to throttle body contact, fixed that and then went for it again,
first pull made 535hp/589trq @ 15.8 psi
pulled some timing on the BTM box, and richened it up on the FMU and went for one last pull
made 560hp/608trq @ 16.05 psi with a nice 11.8: afr then let out at 4800 because i saw 12.8: afr's so i let out of it.
here is what it has:
engine:
318 5.2 stock cubic inch
EQ non ported heads with 2.020/1.625 ss valves
206 210 .480 .500 112 lsa comp cams
fully ported stock barrel intake
fully ported stock throttle body
9.3:1 compression
turbo system:
72mm garrett .84 a/r turbine t4
OBX truck headers flipped
3 inch crossover pipe
4 inch thick front mount
al 3 inch IC piping
hks 44mm gate
tial 50mm BOV
ignition:
crane 6 box
crane BTM box
crane dizzy
crane coil
crane 2 step controller
fuel system:
walbro 400lph in tank pump
92 fuel rails
-6an feed line
3/8ths return line
stock injectors
adjustable FMU
vortech blower carb hat with aux 60lbs injectors kick in under boost
stock trans
spec stage 3 clutch
stock rear end
3.90 stock gearing
this was on 91 octane, 1.21 SAE correction, i live in denver colorado.
462.507 uncorrected if any body is wondering.
was wondering if this is some kind of record or are there guys making this kind of power from a single turbo? didnt expect to make that kind of power! :mullet:
engine:
9.3:1 compression
turbo system:
al 3 inch IC piping
hks 44mm gate
tial 50mm BOV
ignition:
crane 6 box
crane BTM box
crane dizzy
crane coil
fuel system:
92 fuel rails
-6an feed line
3/8ths return line
stock injectors
adjustable FMU
stock trans
spec stage 3 clutch
stock rear end
3.90 stock gearing
