1 - 6 of 6 Posts
i would think no, since the 3.9 is considerably shorter than the 5.2/5.9. might be possible with custom piping, but you're gonna have to pay for it
· "][" {[]} {[]} ][_
Iawtp
Magnum v8s are longer from the front. I see everything working except the bracket on the front and the snout on the sc being too long. But for the work to make it fit i would just grab a powerdyne and play.
· the blue blur...
wouldn't be cheap. like mentioned, the snout is really the problem, everything else would work fine. you could make it work with a custom made spacer and pulley to run an independent belt to it, but you would also have to ditch the clutch fan and go electric or the belt won't clear the clutch fan. centrifugal is much easier, but if you did make the KB work it would be a fun ride with all that extra torque down low.
· ROD-DAKOTA
I have a Dakota 3.9 V6 and I would to setup a Supercharger on, I think that ProCharger for 5.2 maybe work, but the problem is that Brackets and I would to use the Tensor belt part instead the new belt because there is no space between fan and the engine to setup another belt.
Did someone find something good to setup?
Regards
Rod
1 - 6 of 6 Posts
