1 - 20 of 27 Posts
I know that 275/55/17s will fit my R/T all around but my question is how will they look. Will they look too wide for the rim? From like a head-on profile, will the sidewall be like bulging over the lip of the rim? Thanks for the info.
Discussion Starter #4
Awesome! I'm gonna get the Yokohama ADVAN S.T.'s in 275/55/17 all around. I'll let you all know how I like them.
275/60/17 is stock on the Durango R/T with the same rim.
The 275/60 gives you a nicer ride too.
I'm not sure how you guys came up with these numbers. I presume that if you're worried about the tires being too wide, you'd also be worried about them being too tall, right?
The stock tire is a 255, which has a diameter of 28.0 inches, MOL. Going to a 275/55 gives a diameter of 28.9 inches, while a 275/60 gets you a 30.0 inch diameter. Thats a pretty serious change where your gears and speedo are concerned. The 275/60 will cause your speedo to be nearly 7 percent out of whack. Remember that the aspect ratio number is a percentage of the width of the tire, so as the tread gets wider you need the aspect ratio to go lower.
If you want to stay close to stock, try a 275/50, which will give you a 27.8 inch diameter, or a 285/50 with its 28.2 inch diamter. Both are just 2/10 of an inch off stock, which is a lot better than a full inch. You'll be within one half of one percent of a true speedo reading then.
Keepin' It Keebler
Listen to that man!!!
My speedo is so far off it's not even funny.
My cruise was on 70, but the cop assured me i was going 79. :(
No, not really. I can deal with the tire height by using my SuperChips. Tall tires can "look" fat compared to a lower profile tire even if they are the same Section Width. To some people "fat" is the Sidewall Aspect Ratio.
What are you running for tires that gives you a 13% error?
Discussion Starter #11 (Edited)
So if I go with 285s, will I have any rubbing issues?
Also, if I choose to go with an 18" rim, what sort if size tire would be optimal to stay as close to factory specs as possible? 285/45/18? 275/45/18?
Thanks in advance for the help.
Who makes a 285? It would likely depend on the profile. The only problem I have with the 275/60's is turning lock to lock. The tire will rub slightly on the frame. Most likely a 285 would be a little bit worse.
Discussion Starter #13
I'm having a hard time finding a company that makes a 285/50/17 so if I stick with stock rims I'm going to buy the Nitto 450 in a 275/50/17.
I got 285/65/R16.... from Pirelli Scorpian Z's
They are the best tires I ever had on my truck for dry weather.
they fit perfectly, can never go back to stock anymore
i have 285 60 18's on my durango, on 18x8.5 inch rims, they are at around 33 inches tall, it orignally had 31 inch tires...
the speedo is off by a few mph only when ur above 60, its not a big deal at all.. + it looks awesome.
33? A 285/60/18 is approximately 31.46 The stock 31x10.5x15 are approximately 30.5
like guy said, 275/50 for 17's nittos are a good choice. I road on 28" 295/45r18 nittos 555 for a while and liked it alot. I have also had 255/55r18 and 285/50r18 amd 255/45r18
nowi ride on 275/45r18. I have pics of all if you would like to see, the pic by my name is 295/45
the tires should match the wheel well gap
Swap Meet Moderator
Yeah I got 275/40r-17 don't remeber the exact demensions but around 26 inches so ...lol so yeah needles to say at high speed I'm really not doing what my spedo says...lol but 275 should work out sweet for you man I would say just don't go down to the 40's really to small .. I either need to lower the truck more of get my 20's.... :mullet:
Not fast enough!
Yeah I was gonna say something if you were still getting the 275/55's..... Way to big IMO..You'd end up with a bubba tire look.
275/50/17 Nittos are awesome. Ive had mine for a year and have absolutely no complaints. Heck they even hook decent at the strip.
1 - 20 of 27 Posts
