1 - 20 of 21 Posts
I just installed new headlight bulbs, nice bright white light now.
But... I can't run the fogs all the time like I used to, it looks stupid. The fogs are too yellow, and don't look good at all with the new headlights.
Where can I find white fogs that fit the stock location on my 01 Dak QC Sport?
Change the bulb to silvania silverstars!
So it sounds like those are replaceable bulbs? I hadn't looked at that, I thought it was a sealed type, or I assummed so. I will have to take a closer look!
just make sure you get bulbs that have a 90 degree elbow in the bulb housing!
anything xenon super white will brighten em up :biggthump
Discussion Starter #8
I am having a difficult time finding these! It appeasr to be a bulb # 898, which no one carries. An 899 fits Dakota/Durago pre-01 style, but mine and newer is an 898.
The 899 appears to have the same connector, but it is not at a 90 degree, it is straight. Why would it not work? I peeked under the bumper last night, and there is plenty of room....
Found mine on ebay. They are the eurodezigns ones, might find them there or try www.eurodezigns.com
The 891/894 bulb size is compatible with the 898 - just make sure it has the 90-degree connector for 2001-2004 Dakotas/2001-2003 Durangos. The 1997-2000 Dakota and 1998-2000 Durango has a different 893 bulb which has a straight connector, the two bulb designs are not compatible with each other's mounting brackets.
Discussion Starter #11
Stranger, you seem to be full of the answers I am needing tonight, thanks!
SinCity, I'll check those numbers tomorrow, hopefully they will have them in stock!
Discussion Starter #12
Okay, I cannot find any of those number bulbs in a Silverstar, and they are telling me that they are not made. Goon, what exactly are you running, and where did you get them?
This is driving me nuts, not being able to find a stupid light bulb!
Just checked my truck and I have the 894 from eurodezigns, those are listed on the eurodezigns website. Like I said I got mine from ebay, or we have a local custom sound system shop here that dabbles in perfomance parts, mainly for ricers, but they carry eurodezign bulbs. If you have anything like that by you they might be a place to check.
One of the Elite
Go on ebay, and get some bulbs called EuroLites. They should have the ones you are looking for. They are good bulbs. Much like the sylvania silverstars... pure white light, and a reasonable price.
~CYCLONE_06
Discussion Starter #16
I am already running the Eurolite headlights, and my Challenger has a full Eurolite conversion set. I hadn't thought to try where I got the headlights... duh
One of the Elite
Well, if they dont have them, try ebay. ;)
~CYCLONE_06
I just put the sylverstar 893's in my 02 dakota as I have been having a problem with finding 898's anywhere...Its close but the only thing different between the 2 lights are the tabs for the harness to click onto and the 90 degree angle. The 898's have 2 tabs on the side of the bulb and a 90 degree bend, the 893's have one tab on top of the bulb and no 90 degree bend. Its not clipped on but with that rubber grommet like deal on end of harness is really holds her in good and I had no problem at all with changing them out or hooking them up. The mounting brackets werent in the way at all.
does the head lights have the straight or 90 elbow for a 2000 dakota
One of the Elite
As far as I know, all the headlights have the straight in bulb ports. The fog lights are the only thing that are different. The 2000 models fog lights are straight in.
~CYCLONE_06
1 - 20 of 21 Posts
