1 - 6 of 6 Posts
Sideways on Sundays
P1762 (M) GOV Pressure Sen Offset Volts Too Low Or High The Governor Pressure Sensor input greater or less than calibration for 3 consecutive Neutral/Park calibrations.
P1762 (M) Governor Pressure Sen Offset Volts Too Low Or High Sensor input greater or less than calibration for 3 consecutive Neutral/Park occurances. (4-speed auto. Trans. Only)
Let me rephrase that...
It "measures output pressure of the governor pressure solinoid valve". It is attached to the trans remp sensor, inside the tranny pan. YOu only need to replace the sensor if theDRB scan tool says it is necessary. Sounds like it could easily be an outside problem and not a faulty sensor.
1 - 6 of 6 Posts
