Deadtoday said:
I own a 5.9L QC, im just wondering what the different amount of liters means in trucks and any car for the matter... From what ive read, the more liters your car is doesnt mean its faster or anything, what is the difference?
I copy/pasted this from another website on how things work to give a more technical viewpoint of what constitutes engine displacement.
What is displacement?
Displacement is the volume of air "displaced" by the pistons during a single engine cycle. In terms of a single cylinder, displacement is the volume of the space traveled by the piston. The two factors that make up engine displacement are bore and stroke.
To calculate the displacement of an engine, first calculate the displacement of a single cylinder. The formula for the volume of a cylinder:
V = hr2
where h is the height of the cylinder and r is the radius of the cylinder (halfway across). If given the bore (diameter), multiplying it by ½ (dividing by 2) will yield r. h is expressed as stroke thereby giving the formula for engine displacement:
Displacement = Stroke * * (Bore / 2)2 * [# of cylinders]
Note that when Stroke and Bore are expressed in inches, displacement is solved in units of cubic in (ci). If Stroke and Bore are expressed in mm, then calculated displacement (in cubic mm) must be divided by 1000 to be expressed in cubic cm (cc), which is the same as milliliters (ml). Also note that engine displacement is normally expressed in liters (l) by dividing the displacement in cc once again by 1000.
For Subaru's 2.5L H4 released in the U.S. 2000 models, the Bore is 3.92" and the Stroke is 3.11". Therefore:
Displacement = 3.11 * * (3.92 / 2)2 * 4
Keep in mind that the Bore and Stroke numbers are not exact. They are rounded, so the calculated displacement will not be exact. In this case, displacement is calculated as 150.14 ci., but the published displacement is actually 2458 cc (2.5 l), or 149.996 ci.
