So . . . I turn on my headlights and they will not turn on.
The parking lamps light up in both parking setting and headlight on setting, but the headlights will not turn on.
The brights will turn on when you hold the bright on/off switch back on the stalk, but they will not stay on unless I hold the stalk back. Its almost as if the thing doesnt know that the headlights are on.
The fog lights will not turn on in any position.
I checked every fuse in both fuse blocks and came up with nothing. I also disconnected the battery and reconnected it after a minute or so with no change.
The bulbs are sylvania silverstars or whatever theyre called and were replaced roughly a year and a half ago.
Any electronic experts know what is going on here? I sure cant figure it out!
Thank you ! =)
Discussion Starter #2
Is there a headlight relay? I know there is a fog light one . . . If the fog light relay is bad would that affect anything?
Just thought I would quickly update this thread. I ended up buying a new headlight switch on Amazon. It is a Borg Warner and the part number is S2064. Replacing the switch fixed the problem 100%. I think the part was about 15 or 20 bucks.
Hopefully this will help someone!
