Ok I've been on the forums for a few days now and I've been searching and reading threads old and new, but I still have a few questions that I need answered as I've yet to find answers.
1)How do I correct the speedo on my 95 dak sport? If what I read is right then my dakota doesn't have a mechanical speedo cable it is electronic correct? I'm running a stock sized tire with 4.11 gears now and never corrected the speedo what do I need to do?
2) Since I'm still OBD1 being a 95 I'm going to need a 5.9 pcm and injectors from a 95 ram/van with a A518 trans for my swap to keep everything running correctly. The truck has no power options so I'm not worried about losing power windows or lock functions. Are there proms that a tuner can burn like some of the OBD1 gm cars?
3) I'm a little confused on what converter to run on a 5.9 swap. Some say you need a 5.9 converter and some say I can use the one that was on my 318. I would much rather use a converter that has a slightly higher stall but can still be used for towing as I'd like to pull a small trailer with 2 quads on it.
4) Has anyone used a Thumper cam from comp in a towing aplication?
Thats it for now I'm going to keep searching on some other forums any input is helpful.
Thanks-Jeff
Thanks-Jeff
