Even if there was little to no compression on that cylinder?
Yes. And it happens only under load in low RPM.yup, still wont cause the spark plug to fire at the wrong time, or for the combustion to come through a stuck intake valve. Im not saying that you don't have bad rings, just that isn't whats causing your drivability problems. Did you have the popping through the TB before pulling the heads?
Okay, I'll throw that at him.i still vote for a valve too tight
I don't know why he put gas in the cylinder. And he did do a compression check...How come he put gasoline in the cylinder? Why didnt he do a compression check on all the cylinders?
You can easily check to see if a valve was sticking by using a dial indictor the rocker arm, turning the crank, then jotting down each lift exhaust/intake for each cylinder.
So I asked him if the bad rings will cause the popping through the intake/TB, and loss of power. he said yes, because the compression will pass through the rings/engine and find it's way out of the intake manifold...:waiting:yup, still wont cause the spark plug to fire at the wrong time, or for the combustion to come through a stuck intake valve. Im not saying that you don't have bad rings, just that isn't whats causing your drivability problems. Did you have the popping through the TB before pulling the heads?
I will suggest this to him Ed, thanks!You can easily check to see if a valve was sticking by using a dial indictor the rocker arm, turning the crank, then jotting down each lift exhaust/intake for each cylinder.
does that NOT make sense?So I asked him if the bad rings will cause the popping through the intake/TB, and loss of power. he said yes, because the compression will pass through the rings/engine and find it's way out of the intake manifold...:waiting:
Not at all! If the compression went past the rings it will pressurise the crankcase and most likely blow out the dipstick, or gaskets. It wont come back up through the intake manifold. If the valves are sealing correctly, im with Brad on thinking the cat's clogged. Did you ever get any readings with a vacuum gauge before tearing it down?does that NOT make sense?
K, i"m gonna remove that bitch if the new rings don't fix the problemNot at all! If the compression went past the rings it will pressurise the crankcase and most likely blow out the dipstick, or gaskets. It wont come back up through the intake manifold. If the valves are sealing correctly, im with Brad on thinking the cat's clogged. Did you ever get any readings with a vacuum gauge before tearing it down?
no worries! It takes a whole lot more than that to bother meah im just bustin your balls lol not a big deal
I would remove the cat anyways since your going boosted that thing will get HOT!!
