Alex said:
So anychance you could give some simple instructions on how you did it, bomb it?...actual paint gun?...tapped just simple instruction
Sure, used 3M adhesive remover I had laying aroudn to clean the lenses. ThenI just masked off the 3 sections on each with regular masking tap. Used a razor to get it nice and tight to the edges. Got a spray can of each from Autozone. primer, paint, and clear. They have all the color codes. Sanded the sections I wanted to be painted with 2000 grit wet/dry sand paper. cleaned and then put 2-3 coats primer.
let dry.
sand and clean.
3 coats paint. ( I let dry really well between coat 2 and 3 and wet sanded then did final coat.)
3 coats clear.
let dry for 4 days.
took tape off (razor helps)
then waxed and all done.
