1 - 1 of 1 Posts
SoutheastR/T
Horsepower fans know that Trick Flow is all about developing products that provide maximum performance, such as the PowerPort® 190 cylinder heads for small block Mopar.
The heads fit all non-emissions, LA and Magnum-series 318, 340, 360, 5.2L and 5.9L engines used through 2003. That’s right, even Magnum owners can now use readily available LA engine parts such as intake manifolds and valve covers.
Getting into the 550hp area Is now easier with 600hp in reach with these new cylinder heads. Out of box [email protected] flow numbers with a higher attention made towards quality construction make these the new winner. Matching head bolts and stud kits are available.
Revised port designs are highly improved over the Edellbrock cylinder heads with porting and valve changes allowing bigger flow numbers. Special shaft mounted magnum series Harland Sharp rockers are available for those magnum engines.
We are offering special pricing so when your ready to make that next step up in performance contact us and get there easier.
1 - 1 of 1 Posts
