I'm in Kuwait at the moment and my car has a problem with the transmission 2000 5.9 Durango). When i drive fast (nearly full speed) the overdrive switches off and the lamp for "trans temp" go's on. I have to wait with engine off and it is fine. When i drive normal in the city, no problem (at the moment). The ATF fluid has the normal color and the smell is also ok. No shifting problems, everything is fine.
Before, the same was in the city after short drives, a flushed the atf and changed the filter. I need to say there was a front accident with the previus owner and the tranny cooler is a little twisted...
I think about a bigger cooler, but i think also it is maybe only a sensor problem. Any Ideas about my case?
Jens
Jens
