1 - 6 of 6 Posts
what trans does the 03 4.7 Durango have? is it the 45rfe or the 545rfe? I'm also thinking of getting a tune-up done on it, as its last tune-up was at 120k and is now at 295k. I'm curious if I should have a tune-up done on it while I have the engine pulled out for a rebuild. is there any symptoms of loose transmission bands ect? I don't want to spend the money if I don't want to. also, what is normal operation for the transmission, and what speeds should it shift into other gears. and how long it should take? I notice some shifts seem to be slow but that could be me. any help is appreciated.
*blinks*
Dude.
If they DON'T put in new plugs, and I'd expect COPs or coil packs, on a rebuild, they're not rebuilding the motor.
Unless you mean a tune-up on the transmission.
And as I understand it, they're the same transmission mechanically, it's the ECU that determines.
I'd get the transmission serviced (fluid, filter, bands adjusted) as the motor is out also.
RwP
*blinks*
Dude.
RwP
I didn't make it clear, I am doing the engine rebuild my self, just was gonna have the trans sent off to a shop
The rebuild kit for the transmissions are the same whether it’s a 45 or 545 trans. There are no bands in these. Steels and clutches only. I’d recommend Red Alto Clutches.
There are a few known failure points on that trans.
The TCC accumulator spring is one. Be sure that gets replaced/upgraded.
There is an ASTG service / rebuild manual out there. I have the PDF. YOu can find it with a quick search.
1 - 6 of 6 Posts
