If you have a 42re or 46re with 3.9l,5.2l,or 5.9l engine, the range sensor is located
on the driver side just behind where the shift cable hooks up to the transmission.
If you have 4.7l engine the transmission is a 45rfe and sensor is internal as part
of the valve body.
Good Luck Daddyododge
Hey guys!
Im thinking of doing some mods to my good old 01 durango slt.
I really want to get a new muffler but im not sure which way to go, just to give you guys a background this 2001 Dodge Durango its my daily driver, I drive it from home to school and then to my job. I want a different...
2003 V8 4.7L club cab
Replaced blower motor and resistor today and it still does not blow anything! Fuses fine. Just stopped working for some reason. Thermostat maybe? Any ideas? It seems to get a little warm but when dials turned nothing happens. Rear defroster button lights up and works. All...
Hey guys,
I have a 99 Dakota 3.9L V6 and I'm having an issue with luke warm heat coming from the vents after the truck is fully warmed up.
My thought is maybe the blend door actuator is messed up, but I'm not sure. The heater hoses going into the heater core sem pretty hot ~160 F on the top...
Hi guys, new user. Need some help with my mom's truck. She's got a 2005 Dakota 3.7 V6 Crew Cab 2WD. Two separate issues: First she dropped all her coolant and overheated, ends up the water pump and thermostat are leaking and going to get replaced. Second issue (unrelated to the overheating I was...
2000 Dakota SLT. My blower motor has been shutting off and turning back on at random for awhile and recently decided to only work occassionally. If i'm not mistaken, if the blower needs replaced on a 2000 Dakota it requires pulling the dash?!?
I could use some tips of where to test probe the...
